| | | Forums66 Topics128,285 Posts1,058,535 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#65122 08/31/2006 6:38 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Can a 53 235 babitt be converted to full presure lube by changing the crank and oil pump? has any one tried this?
"It ain't a truck if you can't hose out the cab."
#65123 08/31/2006 6:49 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The thrust bearing is narrower on a full pressure crank than the splash crank so some work on the block would be necessary.
See the USA in your vintage Chevrolet! My Blog | | |
#65124 09/01/2006 2:41 PM | Joined: Dec 2005 Posts: 324 Member | | Member Joined: Dec 2005 Posts: 324 | Thanks for the info, Dave
