3 members (Gdads51, Ponchogl, mick53), 39 guests, and 2 robots.
Topics128,090
Posts1,056,018
Members48,430
I just acquired a '53 3600 and wanted to do all of the lube work. Everything took grease OK except both lower king pin fittings. I removed the fittings and cleaned them out and ran new grease through them. They were packed with old "crud" when I started cleaning them. I reinserted them and still could not get any grease to pass into the king pin. Is there any method to soften what is in there and soften it enough to flush with new grease? Must I take the whole front end apart to clean?
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
Might want to try warming up some with a torch. You can also put a jack under the axle and raise it enough to take a little weight off.
Don,
I had the front end up so that I could get underneath to lube everything.
I had the same problem the first time I tried to grease the kingpins. I warmed up the area with a torch to soften up the old grease and then the new grease flowed right in.
How hot would you suggest warming it? Warm to the touch? Hot to the touch? Or hotter than comfortable to touch?
Till the old grease starts to sizzel, be ware of hot splattering grease.
And don't get it hot enough to start burning!
You could have other flammable liquids in that area if you have any oil or gas leaks. I agree with the heat approach but would roll the truck outside and encourage caution as you work.
I've seen undercoating catch fire and burn too...
I heated each side several times, warming as I went. Grease came out of the nipple but when I applied pressure to fill it, they "may" have taken a small amount but no grease extruded from around the joint. I may give it a rest and try again with more heat.
Thanks for the input.
I had the same problem with a 58 1/2 ton.Tried everything to get grease intp king pins and spring shackle bolts.Finally bit the bullet and rebuilt the shackle s and king pins. They grease easily now. I was suprised with the amount of rust and crud in these joints. No wonder they would not take grease. I found two broken shackle bolts that would take grease.This is not a fun job.Wish you luck.
1954 Chevy Half-Ton
More pix on Shutterfly
More pix on Photobucket
1958 Chevy 1/2-Ton Stepside
"Time's fun when you're having flies." ~~ OLD FROG
