6 members (tclederman, gswbbc, TIM ZINDLER, HandyAndy, Stovebolt48, rfs56trk), 94 guests, and 2 robots.
Topics128,040
Posts1,055,478
Members48,424
#650981 05/30/2010 10:18 PM
I am looking at what the seller says is a 235, year unknown. He says the engine serial number stamped to the rear of the distributor is F1023J. I can't find that in the sources that I have had access to. Any help?
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
F- built in flint
10- built in October
23- built on the 23rd day
J- Type-Std. 6 -cly. 235
I beleive the year is 58 to 62
Manual trans
145 HP
Pete
John,
If you want to know the year, here are the locations of casting codes.
Tim,
This is a big help with the year but how can I tell if it is a 235 or 261 or something all together different? Especially if I am trying to identify and confirm what someone is offering over the phone.
What year is the block? If it is 58-63, have the person tell you the sizes of the holes in the block for the oil filter lines. If they are 1/2" NPT, you most likely have a 58-63 261 engine.
You can tell 261/235 from block casting code.
In order to know long-distance what you are dealing with, the seller will have to tell you these things over the phone, I guess.
Pete52 has good reason to suggest 58-62 engine - that code looks to be a 235 code (the J at the end).
F1023J : I think on a 261 that the J would be a P (and maybe an additional letter) on a 6xxx series truck (this code might be different for different years and for different option-combinations).
