| | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | I am looking at what the seller says is a 235, year unknown. He says the engine serial number stamped to the rear of the distributor is F1023J. I can't find that in the sources that I have had access to. Any help? Thanks John | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | F- built in flint
10- built in October
23- built on the 23rd day
J- Type-Std. 6 -cly. 235
I beleive the year is 58 to 62
Manual trans
145 HP Pete
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | Tim, This is a big help with the year but how can I tell if it is a 235 or 261 or something all together different? Especially if I am trying to identify and confirm what someone is offering over the phone. Thanks John | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year is the block? If it is 58-63, have the person tell you the sizes of the holes in the block for the oil filter lines. If they are 1/2" NPT, you most likely have a 58-63 261 engine.
You can tell 261/235 from block casting code.
In order to know long-distance what you are dealing with, the seller will have to tell you these things over the phone, I guess.
Pete52 has good reason to suggest 58-62 engine - that code looks to be a 235 code (the J at the end).
F1023J : I think on a 261 that the J would be a P (and maybe an additional letter) on a 6xxx series truck (this code might be different for different years and for different option-combinations).
