1 members (Hotrod Lincoln),
74
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 18 New Guy | | New Guy Joined: Feb 2004 Posts: 18 | So, My cam thrust plate was damaged (long story). I ordered a replacement from headbolts.com, but the replacement came with a 'spacer' and a wider opening than my orig. plate.
does anyone know where to find a replacement plate? (Jim carter is on backorder) | | | | | Joined: Feb 2004 Posts: 18 New Guy | | New Guy Joined: Feb 2004 Posts: 18 | i ended up using the plate and the spacer. IT looks like the spacer is included to make it easier to install the cam gear.
Everything looks good so far. It was too dark to install the crank gear last night. Today i should have here all patched up and hopefully i'll be bolting back down the road. | | |
