1 members (Cosmo),
84
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Hi I have a 57 GMC 1/2 ton pickup and i am currently tearing apart the front end. Im doing a complete overhaul of the systems and i was just wondering is it really worth it to convert from ball bearings to tapered roller bearings? I am sticking with front drum brakes and the only thing that iplan on changing with the brakes is putting in power brakes. I know that the roller ones are a little more expensive but if its necessary than i'll pay. Any ideas? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I kept the stock bearings on My 52-3100 cleaned and repacked them but My truck is stock ,216,3 speed,3100 so I'm not going to go any faster than the truck was doing before I started ,if I put in a V8 and disk brakes than for sure I would change the bearings ,more heat and stress on the bearing due to faster speeds and harder corners.
Pete | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | If your bearings are in good shape there is no reason to change them. | | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Ok then i think i will tick with the original type but i do need new ones because i noticed some scaring on the racers. I was looking at the ones that LMC has and in the catalogue they have the front wheel bearings but it does not show in the picture or description about the bearing racers. Do they come with the bearings? Probably a dumb question but i'll ask. Just dont want to spend the money and not get everything. thanks | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The tapered rollers conversion is $99 + $12 ship in Ebay. (both wheels: bearings, and seals). The ball bearings inner and outer with seals are at $100 each wheel or more ($200+). Do the math. and consider the benefits. No TF truck should keep (stick with) the balls especially when it's time for new ones or a "rebuild". Classic parts of America, a sponsor to the Stovebolt, has them at $119 minus our %10 discount ($107) plus ship. This may be cheaper, or equal to, the first example depending on your zip. Get em and be happy. There is no question they are better at load handling and wearability. Bearings always come with races. Ball bearings may be a single unit. Tapered roller bearings have press in races with matched tapered roller inserts. Bartamos.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Do you use the rear bearing dust shield with this setup ?
Thanks,Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | rear bearing as in, rear wheel or inner bearing on front wheel? Assume you mean inner brg, I don't know yet, have not started that area of project yet. Will PM you when I do If you still want to know.
