I bought a new 12 volt gas gage for my 1950 3100.
I had 2ea 6 volt clusters and they were both bad.
the new 12 volt cluster is slightly thicker than the original 6 volt and the needle on the new gage sets up to high and hits the bezel.
Any one else have this problem with the new 12 volt cluster?
I made a spacer for the bezel to make it work. Glued it to the back. I could of bent the neddle but didnt know if I would damage the new gage
pics This may intrest you if your converting to 12 volts..., if you have a good 6v gage go with the reducer
