8 members (mick53, Lostbuthaulinass, carbking, Southerntruck, Otto Skorzeny, 1955 1 Series, 52Carl, cmayna), 154 guests, and 0 robots.
Topics128,114
Posts1,056,282
Members48,439
#64989 08/29/2006 3:58 AM
Need some advice from the Xpurts.
Rebuilt a 261 engine fairly stock ...circa 1959 and when installing the exhaust manifold I replaced the unthreaded studs (locating studs ? )at either extremes ends of the exhaust manifold with grade 8 bolts.
Guy came over my place and said that my manifold would break with these bolts in place once the engine was fired up and came up to running temp.
He further suggested that if I was concerned with sealing the exhaust manifold that I should install regular studs and use brass nuts as they would allow for some expansion on the hot manifold.
Who is crazy... me for trying to seal the manifold with an extra bolt or does his gray hair means he is wise....???
Need to know before I fire my engine up and cause grief!!!!
Thanks for your help
Bob Carriere
Bob C.
CMP Heaven
The Hammond Barn
Done that to mine, no problems at all. Also, the fellow that did my machine work (50= years doing it) told me that that was a good idea. Seems that was an old trick to get good sealing. I did convert the other bolts to studs/nuts though.
By the way, I used stainless nuts, not brass.
Bill Burmeister
I kind of hate to use grade eight bolts anyplace where they might have to be drilled out. This can happen with any bolt in an exhaust system. Since this is not a high tension application like a rod bolt or a wheel stud wouldn't a grade 5 do just fine? An 8 is just so hard to cut or drill.
Evan
I have also had no problems using grade 8 equivalent stainless steel bolts to hold manifolds (Offenhauser intake and Fenton exhaust) to a 261 engine (including bolts at the two ends where studs were originally placed). Been running the engine this way since 1998.
Riding in the Passing Lane
Ive put bolts or studs on the manifold ends for years on the 250-292s . Works good. I use grade 8 bolts on every thing. It is less likely you will have to drill them out.
1972 Chevy c10 Cheyenne Super
#64994 08/29/2006 11:28 PM
Do the original studs just twist out, like a bolt?
#64995 08/29/2006 11:53 PM
Ex Hall Monitor
Ex Hall Monitor
Yes.
Gentlemen thank you..... I consider the Brass nut myth "Busted"......
Always wanting to be safe I will change my 2 grade 8 bolts for SS and coat them with Never Seize...... just in case.
Your practical expereince is appreciated.
Bob C.
Bob C.
CMP Heaven
The Hammond Barn
