2 members (porsche, Dennys28), 93 guests, and 2 robots.
Topics128,051
Posts1,055,766
#64983 08/28/2006 10:47 PM
Apprentice
Apprentice
I am in the process of rebuilding my '54 235 and I was wondering what everybody was running for camshafts.
1953 3600 w/ full pressure 235
"Quando Omni Flunkus Moritati"
--If all else fails, play dead.
#64984 08/29/2006 1:59 AM
I'm running a Howard M4F 3/4 race cam, mild grind. This one is a solid lifter cam. Nice lightly rumpy idle. If your engine is a truck or passenger stick shift, you will need to go with a solid lifter cam, the block isn't drilled for hydraulics.
Bill Burmeister
#64985 08/29/2006 2:02 AM
this has come up before, search the forums, but for a 235 full pressure engine...
tom langdons bulldog grind
patricks 3/4 grind... close to howards m4 grind
a 261 chevy stock cam
a regrind with the same specs as a 235 corvette
or grind your own at delta
