7 members (Joe H, JW51, Millenimech, dt235sd, Eisenholtz, klhansen, Ponchogl),
109
0
Mod | | | Forums66 Topics128,051 Posts1,055,764 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64983 08/28/2006 10:47 PM | Joined: Dec 2004 Posts: 33 Apprentice | | Apprentice Joined: Dec 2004 Posts: 33 | I am in the process of rebuilding my '54 235 and I was wondering what everybody was running for camshafts.
1953 3600 w/ full pressure 235 "Quando Omni Flunkus Moritati" --If all else fails, play dead.
#64984 08/29/2006 1:59 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm running a Howard M4F 3/4 race cam, mild grind. This one is a solid lifter cam. Nice lightly rumpy idle. If your engine is a truck or passenger stick shift, you will need to go with a solid lifter cam, the block isn't drilled for hydraulics.
Bill Burmeister | | |
#64985 08/29/2006 2:02 AM | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | this has come up before, search the forums, but for a 235 full pressure engine...
tom langdons bulldog grind patricks 3/4 grind... close to howards m4 grind a 261 chevy stock cam a regrind with the same specs as a 235 corvette or grind your own at delta | | |
