5 members (Ponchogl, Jack Ryan, Shade Baby, Hotrod Lincoln, 1 invisible), 71 guests, and 2 robots.
Topics128,026
Posts1,055,410
Members48,422
#649691 05/25/2010 11:56 PM
I'm not having much luck searching the forum, so here goes.
I'm assembling a '58 235 with solid lifters. Most of the charts give valve clearance for a HOT engine. What is the correct clearance for the initial (cold) adjustment???
Gary
ggfossen #649692 05/25/2010 11:58 PM
Ex Hall Monitor
Ex Hall Monitor
Don't know if this is "correct" but I set my 216 to the specified lash cold which was close enough to start the engine, then reset to correct after normalizing the engine temp. Worked for me.
Tiny #649702 05/26/2010 12:55 AM
You can give the rockers a 2-3 thousandths more lash cold, then adjust to the specification hot- .008" and .015", intake and exhaust, if I remember correctly. I don't have the specification at my finger tips, but I'm sure someone else has.
Harvester
Hot Settings:
0.006" Intake
0.018" Exhaust
Harvester's cold lash "add-on" looks good. Some Shop Manuals say to "roughly set the valve clearances to make sure the valves have clearances". Some people say to set them up to 0.005" wider than the hot settings.
Amazing how quickly the responses arrive on this forum.
I just set them at .008 and .015 as I need to get them someplace close. Looks like I am now OK for initial start.
I still have quite a bit to do before I can crank it. I have not even started on sorting thru my generators and starters. I will try to get a new oil pump tomorrow, and I still have to decide what I am going to do about the water pump. The old water pump (one of them) looks good, but I will have to find a large diameter pulley that is shorter, and see if I can press the whole mess together. If not, I will order a spendy pump.
Thanks for the quick and reassuring responses.
Gary
