0 members (),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,875 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | So...I decided to take apart my transmission to my 1954 Chevy Truck (235 engine) to diagnose an issue with the 2/3 shifter lever not moving. Long story short is I pulled out the spline from the rear and the needle bearings all fell out.
What is the best way to get the bearings all back in correctly? Mind you this is my first experience working on a vehicle. Any help is appreciated.
Carlos | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I coat the bearings in grease so they stay on the shaft to get them back in.
Pete | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's it Pete, heavy fiber wheel bearing grease. DG
Denny G Sandwich, IL
| | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Thanks guys. Is there a drawing somewhere that can show me where to replace them...they literally all fell out. I have two sets, skinny ones and fatter ones. Also, is there I have wheel bearing grease, is that the same thing?
I appreciate the help. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
| | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | DG,
I am not seeing where the bearings are located?
Carlos | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | #7 main shaft needle bearings #23 countershaft needle bearings
How many needle bearings of each do you have?
-Tom
1950 Chevy 3100 w/ 1956 235
Carlos | | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Sorry for the repeat posts...my computer was possessed. I have around 24 smaller bearings and maybe 16 fatter bearings. they are at home on my work bench. I have been looking at a chop manual, in fact I enlarged an image of the layout of the transmission and will work on this over the weekend.
Thanks for all the help...I'll let you know how it goes and how many expletives are launched
Cheers,
Carlos | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Any wheel bearing grease will work, as long as it holds the bearings in place long enough to get it back together. Grease that is "heavy fiber wheel bearing grease" is thicker and stickyer, than most.
Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Apr 2010 Posts: 283 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 283 | This sounds like you are describing the 2 rows of needles found in the main drive gear which is the gear that extends into the clutch disc. This is normally the first gear removed from your trans but the needles still fall out. It is the last gear installed and from the front with the ball bearing still mounted unless it were a close ratio gear set but that wouldn't be in an early truck.So! 1) Reinstall the tailshaft without the needles after removing the main drive gear. 2) using grease stack the large needles in the main drive first-then there should be a thick washer between the large needles and the small needles which are stacked in next. 3) If the needles still are wanting to fall out when the main drive is slipped in place, find a way to rest the trans with the tailshaft pointing straight up then gravity will not be working against you so hard. 4)sometimes one of the needles,usually a small one, is dislodged when the main drive is slipped in and will prevent the gear from going all the way home.If the main drive doesn't go in far enough for the bearing retaining ring to go easily up against the case-take it back down and start over-DO NOT try to pull the main drive home with the bolts in the collar. 5) note the drain hole in the front of the case and the matching channel in the release bearing/main drive gear collar-they must be lined up as this trans has no front seal. If the 2-3 shifter fork is locked up it probably is the fault of the syncronizer which selects 2 and 3.
Bob Taylor
| | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Larry - Thanks for the tip, I got a hold of some grease that you suggested.
Bob - I appreciate you walking me through the steps. I will work on it this weekend.
I really appreciate all the advice.
Carlos | | |
