| | | Forums66 Topics128,149 Posts1,056,816 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 28 New Guy | | New Guy Joined: Dec 2008 Posts: 28 | I'm putting a sbc in my truck and I'm using the factory serpentine belt setup. I was told that requires a water pump with reverse rotation(not reverse flow). I was also told that I can hook the heater core to the plumbing on the intake (1/2") and return it to the lower radiator hose. Does anybody know if that is correct? If so how do I hook to the lower hose with the 3/4" heater hose? Thanks. | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | There shouldn't be any reason to change the heater core flow. Once the coolant exits the water pump, flow through the engine is identical to the coolant routing of the clockwise-rotation pump. The fitting in the intake manifold just below the thermostat will still get pressurized hot water, and there should be a return fitting in the pump inlet for the heater return line. Some GM radiators route the heater outlet to the downstream radiator tank. Way back in the dark ages, Ford flathead V-8's had a screw-in fitting in a hole in one of the lower radiator hoses for a heater return, but I haven't seen one of those in at least 40 years. Jerry
| | | | | Joined: Mar 2005 Posts: 98 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 98 |
50 chevy 3100
| | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Also using the stock serpentine belts and one of these T's. They work great.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 |
