8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC),
82
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64749 08/24/2006 2:09 AM | Joined: Apr 2006 Posts: 19 Junior Member | | Junior Member Joined: Apr 2006 Posts: 19 | I own a 1952 GMC with a 228, i recently purchased a dual carb ellis and i need carbs for it. The intake came with 2 zenith carbs but they are not repairable. Can someone recommend some carbs to put on the intake? they dont have to be zeniths. I was thinking rebuilt rochesters that are cheap. | | |
#64750 08/25/2006 1:31 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Carters or Holleys would be a better choice over the Rochesters. They are about the same cost. The 2100S Carter would be perfect, just make sure to get a matched pair, some rebuilers will slip ford units in a GM box.
Bill Burmeister | | |
#64751 08/25/2006 6:10 AM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I have used rochesters on a Nicson two carb manifold with no problems, just match up everything, i.e. jets,etc. | | |
#64752 08/30/2006 11:01 PM | Joined: Apr 2006 Posts: 19 Junior Member | | Junior Member Joined: Apr 2006 Posts: 19 | i recently purchased 2 NOS zeniths for $125 each...did i pay to much? | | |
#64753 08/31/2006 12:33 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's a pretty good deal. Most single barrel carbs I've priced are around $160-180 for a reman.
