4 members (Cosmo, dt235sd, Gray_Ghost, Gdads51), 84 guests, and 2 robots.
Topics128,060
Posts1,055,840
Members48,427
#64749 08/24/2006 2:09 AM
Junior Member
Junior Member
I own a 1952 GMC with a 228, i recently purchased a dual carb ellis and i need carbs for it. The intake came with 2 zenith carbs but they are not repairable. Can someone recommend some carbs to put on the intake? they dont have to be zeniths. I was thinking rebuilt rochesters that are cheap.
#64750 08/25/2006 1:31 AM
Carters or Holleys would be a better choice over the Rochesters. They are about the same cost. The 2100S Carter would be perfect, just make sure to get a matched pair, some rebuilers will slip ford units in a GM box.
Bill Burmeister
#64751 08/25/2006 6:10 AM
I have used rochesters on a Nicson two carb manifold with no problems, just match up everything, i.e. jets,etc.
#64752 08/30/2006 11:01 PM
Junior Member
Junior Member
i recently purchased 2 NOS zeniths for $125 each...did i pay to much?
#64753 08/31/2006 12:33 AM
That's a pretty good deal. Most single barrel carbs I've priced are around $160-180 for a reman.
Bill Burmeister
