8 members (Oldcaliforniakid, Otto Skorzeny, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86),
114
0
Mod | | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Up until I removed the center hinge to separate the two hood halves on my ’41 I had no idea that there is no center pin. I had just assumed it was a sort of piano hinge. How long had Chevy been using that design? Did older models use a piano hinge? | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Not sure what you mean by " no center pin " ? There is wire core that threads thru the center of the hinge sections. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Hi Bruce:
You may have inadvertently answered my question if your '40 has a wire core. My '41 does not have any type of core. The two hinge halves seem to be designed to work without any type of core or pin, each side is continuous for its entire length. By removing the front hold down you can slid one half of the hood forward (slipping one half of the hinge through the other) and completely off of the truck while the other hood and hinge half remains in place on the truck.
The hinges on the side panels are the piano hinge type that has a wire core.
Hopefully a few more guys will chime in and help clear this up.
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Hi back Kip. You are right / please excuse my brain malfunction *g*. Its been a while since I did my truck. The centre hinge sections slide into each other while the side panels have the piano type hinges. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Someone must know when Chevy used a center pin and when they went to the pinless design. | | |
