| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | So I've got this '49 half tonne I bought last year, and I have yet to turn it over. I had previous starter troubles, and now I've gotten another. I've tested this starter on the bench, and when I have it on the bench, it'll turn and spin really nice when I jumper a battery to it.
This is the puzzler though; once I bolt it into the truck, it shorts. Doesn't even turn a little bit. I'm not using the truck wiring, this is just with a pair of jumper cables, one to the terminal, one to ground it. I've tried it so many times now. Shorts everytime.
Is there something I'm missing here? I appreciate your advice and insight as always.
Matt
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Is the engine stuck? Can you turn it by hand? There could be bad bushings in the starter that lets the armature drag on the poles when under load. The drive may be engauging before the motor starts to turn. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | What do you mean by "it shorts"? A "short" is a term meaning short circuit. In other words the electricity is getting to ground before it completes the circuit to where it should be going. | | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | Sorry, a little more information that I forgot to mention:
The engine turns freely by hand, a full 360 degrees.
When I say it shorts, I mean the terminal crackles, or sparks, and sort of fizzles. Same behavior as when you simply short the battery.
Like I said, it doesn't really make sense to me. I'm quite experienced with circuits and wiring, so having it short like that is puzzling and extremely frustrating.
Is there anything I should be trying, something I may have missed? Thanks for the quick replies by the way. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Take the starter off the truck and bench test it.
| | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Read for resistance from motor terminal on starter relay to motor frame. You should get 1 meg ohm or better. If very low - 1 0r 2 ohm I would check and ensure cable lug at motor is not touching motor | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I'm a little confused. Do you have a battery in the vehicle? If so, it should be a 6 volt positive ground. Are you using jumper cables from another battery and possibly crossing polarity with the battery thats in the vehicle? If you have no battery in the vehicle, its pretty hard to get enough amperage through most jumper cables to crank a 6 volt. If you have light jumper cables, its quite likely that it will only sputter at the clamps. I use 4/0 cable with 500 amp welding clamps for a jumper cable on 6 volt. | | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | tclederman - I have bench tested the starter per the service manual. I even have a growler and it tested fine on that too.
crenwelge - I have tried it with the battery in the vehicle, and with the battery on the floor with a pair of jumper cables. It is a good, 6 volt battery with a full charge. Yes, I did hook it up with a positive ground. You might be right about the amperage though. I'll try it again this evening, no jumper cables, battery in the truck. The battery cables in the truck, should they also be at least 4/0? I thought perhaps it was a bad ground, but settled on a short due to the sparking. I'll update with my results soon as a get in the garage.
Thanks! | | | | | Joined: Apr 2008 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 44 | Well, I kinda feel dumb now. It's one of those things you always read, and you just look at it, looks good, must be good.
Bad ground somewhere. I took off all the ground straps, and the battery cables, and got everything to nice bare metal. Terminals too. What do ya know, it turned over. Seems I've learned, once again, to always check the basics first.
On the bright side, I heard it turn over for the first time today! It sure did put a grin on my face! | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | 4/0 is actually overkill, but it is what we have at the shop for our 18 wheelers. 2/0 is enough for 6 volts. | | |
