2 members (Otto Skorzeny, VicZ),
122
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,059 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | So the engine (v8) and transmission are not stock, nor am i sure what they are out of, etc. But the location of the manual shifter coming thru the floor is extremely (almost dangerously) close to the pedals. The top of the shifter is literally under my leg in first gear! You should be able to see in the interior picture that there is a slight bend in the shaft. What i was wondering is if i took a 3" or 4" piece of aluminum, steel, square bar, etc and mounted it directly to the transmission in the current place of the shifter and turn the shifter shaft 90 degrees so the bend is going towards the passenger and mount it to the bar, if this would work. I know it's kind of a "band-aid" of a fix, but is there anything else i could do??
My apologies also for any incorrect terminology! Thanks guys! | | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | It looks like you've got a Mr. Gasket #7667 pickup shifter. ( Link) If so, the shift lever bolts on and you can make one out of some steel rod to fit your cab and seat. Here's a link to the install instructions. Another option is Patrick Dykes ((520) 836-1117) shifter for the Saginaw 4 speed. It enters the cab at the same location as the factory SM-420 trans stick does. You could use it with a 3-speed by locking out the reverse lever. regards, Leon | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Do you have a 3spd or 4spd? With the V8 conversion, and the engine in the rearward position the shifter will exit just in front of the seat. Yours appears to have the engine forward allowing the shifter to exit midway of the transmission cover panel. Your idea of fabricating the shifter/stick will work, but it might make the shifter more sloppy. I just went thru this with a "cheap" 4spd shifter. I purchased a used "namebrand" shifter and it eliminated all the slop and long throws. | | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | I'm not sure if it's a mr shifter, but looks like it is. It's a 3-speed v8 though.so getting one of these used name brand shifters you mention, will solve my problem of the shifter being in the way...? Right now it's an "H" configuration on shifting, would these make it linear? How easy/difficult is this swap out? Thanks | | | | | Joined: Apr 2010 Posts: 362 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 362 | Had one like that on my 56 and 57 with 3 spd. All I did was heat and bend the shifter rod itself and bend it out to right a little. Worked back then, 25 years ago, should work now.
58 gmc 100 with 350 sbc
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | Yes LarryW I did the same thing on a 54 Ford too. You really do not need much heat on the shift Rod just a little heat and some constent pressure. Then take some polish after it cools down and it will shine back up if it is chrome. You might also make some bender bars and bend it cold. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | shouldn't be much of a chore to clamp it in a vice, heat it and bend it. That's what I did on my first 59 gmc pickup. You might want to use a towel or oven mitt after you heat it. | | | | | Joined: May 2010 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 47 | Roughly wear did you guys bend it at? Anyone have a picture? And/or an installed picture? | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Try this, upover up bracket, then just bolt your shifter to it via two holes. The entire shifter bracket is home-made (sure looks it)and has been working well for several years. Shifter is in the middle of the floor.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
