2 members (Steelonsteel, carbking), 113 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
#64722 08/23/2006 5:47 AM
Here's a thought...... I was wondering if anyone has? or what the possibilities were.. of awapping out the OEM 4-speed/granny in my '49 2-ton... with a BW T-85 W/overdrive..... As I'm thinking it would give better roadability......
Michael
\'48 chev 2-ton boom truck (Boomer)
'49 Chev 2-ton flat bed
'65 Chev 35ft school bus
'88 GMC 6500
'72 Superior 26ft class "A" coach
'50 Farmall "M"
'71 MGB GT
'68 Austin-Healey Sprite
'65 Austin-Healey Sprite
and various other odd British cars
and lots of old radios.....
Although we know what the speed of light is..... What I want to know is... How fast is the speed of DARK??
#64723 08/23/2006 6:12 AM
it would have a better highway speed for sure .... if you weren't doing any heavy hauling it should work fine
#64724 08/23/2006 2:38 PM
ODSS President
ODSS President
27% gear reduction. I have mine set up to split all three gears giving me a 6 speed, 3 under and 3 overdrive. I have a 'Reminder Light' (light is 'ON' when OD is engaged) set up so that I DON'T START OUT IN OVERDRIVE. You don't want to do that if you want the OD to last.
~ Cosmo
1949 Chevy Half Ton
#64725 08/23/2006 8:02 PM
Anonymous
Unregistered
Anonymous
Unregistered
Seems like a pretty small, light duty tranny for that size truck. I would expect trouble.
#64726 08/23/2006 9:34 PM
The NV4500 transmission may be a better option. It comes with a pretty low 1st gear of about 5.61:1. It has an Overdrive of .73:1. These transmissions are found in both 3/4 and 1 ton Dodge and Chevy trucks. They are considered to be bulletproof.
You need to think about speedo hookup. Do you have a 2 speed rear axle? If not, your speedo cable prolly goes to the transmission. Many of the newer transmissions are set up for electronic speedos. If you plan to use your mechanical one, this could be an issue.
If interested in the NV4500, look for a unit from a 1992-1997 Dodge 2wd 2500 or 3500 series truck. You probably won't want the unit from a cummins diesel engine because it has a larger input shaft and won't work with your stock clutch.
Why the 92-97 dodge unit? The 92-97 dodge units are the only version of this transmision that come with provisions for a mechanical speedometer. The input shaft is also 1 inch longer than the Chevy version. This allows you to have an adapter plate made to go between the bellhousing and transmission and allows you to use your stock clutch set up. The input shaft should be the same as your stock tranny... 10 spline 1 1/8 diameter.
Hope this helps.
