1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 59 | Hey all,
Are the upper and lower mast jacket bearings and rag joint the same on a 1966 C50 as they would be on a light duty 1966 Chevy truck? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Brian Lohnes, the 67 light truck upper bearing is the same as the 66 bigger trucks as is the coupling [ragjoint]I cannot seem to find a number for the lower bearing for the light trucks, the part number for the big truck lower bearing is 9418383, hope that helps. | | |
