| | | Forums66 Topics128,015 Posts1,055,335 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#64658 08/21/2006 6:53 PM | Joined: Sep 2002 Posts: 467 'Bolter | | 'Bolter Joined: Sep 2002 Posts: 467 | I got a chance to get a deal on a rebuilt 235 for my 51. The 235 in there now has a small crack in the block. Is there anything in particular I should be looking for when I go look at the motor - were some 235's different and better suited for the truck? Any help appreciated. | | |
#64659 08/22/2006 12:55 AM | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mapleleaf, short water pumps on 54-55A 235s make them an easier swap into older trucks, no point in getting one older than 54 [53 Canadian] for the better bearings. Newer engines have a longer water pump that will need to be replaced with a custom short shafted one. Hope that helps. | | |
#64660 08/22/2006 4:32 AM | Joined: Mar 2001 Posts: 327 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Mar 2001 Posts: 327 | Here is a few things to look for if yer shopping for a 'new' 235 or 261 for your 'new' truck. A quick glance will let you see if it has four bolts holding the valve cover or two in the top of the valve cover- you ONLY want the ones with the four bolts for the valve cover. next, check the head for numbers- hopefully you will see an '848' in that long number- not real important but it is the better head. I would then want to pop the head to see, what/if any, over size the pistons are. Also you can check the cylinder walls at this time. If you are planning on keeping this rig for a long time you want some play room when you rebuild it. You will also want to pop the pan and check a main bearing and see how far it is over size. Either of these I would think .010 over size is OK but over that you might not want. Replacing a head gasket and pan gasket can save you loads of money and problems down the line. Look the motor over real good, inside and out, before you buy it.
Oly in Oregon Rest in Peace1945 GMC COE Victory Truck 1953 Willys CJ3B 1955 Chevy 1st series 3/4-ton 1958 WIFE Last series Never say "Whoa" in a mud hole
