7 members (Hush, 55shaker, 5 Window 9434, 1955 1 Series, Otto Skorzeny, Wayne67vert, Gib70), 71 guests, and 4 robots.
Topics128,090
Posts1,056,368
Members48,442
Hello,
how could I remove the oil pump of a 235 engine without to remove the engine?
One problem(?) the heads of the srews that fix the oli pump have round heads Is that normal or are they damaged?
Ask
Wolfgang
I'm working on a Chevy Pickup 3600, build 1953 with an 235 cui engine.
Here you can watch my truck: https://www.kripahle-online.de/unterricht/?page_id=2532
Those round headed bolts should not be removed. They were used to secure the distributor mounting and the hole was line bored afterwards in the factory.
To remove the oil pump, remove the pan and the plumbing to the pump. Then remove the set screw on the oil pump shaft that is up near the inside wall of the block. The screw has a locking nut at the base.
1951 1 Ton Completed
Observe how much machined area of the pump stem sticks out of the block so you will know when you have it back in completely. They sometimes need a little persuation.
