7 members (DuckRancher, 55shaker, TexasA&M48Truck, 1955 1 Series, sron48, Doug Boudreaux, 1 invisible),
77
Mod | | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 49 New Guy | | New Guy Joined: Nov 2009 Posts: 49 | I have an opportunity to jump in on an order and save some big bucks on a new set of wheels and tires for my 1946 1/2 ton. The problem is that my truck is apart being painted so I cannot get the measurements I have been asked for.
I am looking the measurement from the drum to the inside of the front and rear fenders. My truck is all original. I believe all other measurements can be taken from my truck once I have this reference point to work from.
The pictures of original trucks seem to show there is some room to play with. I hope that is the case. Any help would be appreciated. Thanks, Aaron
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Look through HERE. You should be able to find the info you need...joe | | | | | Joined: Nov 2009 Posts: 49 New Guy | | New Guy Joined: Nov 2009 Posts: 49 | Thanks Joe. I was looking this over last night (page 57). The numbers are not too clear but I am sure I've got it right. I will compare the numbers that I can against my truck, just to be sure. The best I can expect is to be fairly close. It will have to do as today is my last day to get it sorted out. Thank you. | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | | | |
