8 members (Charles in CA, Nick in Manitou, 51sub, TUTS 59, Bill Hanlon, 1955 1 Series, NJC, WICruiser), 130 guests, and 1 robot.
Topics128,265
Posts1,058,360
Members48,485
#646322 05/14/2010 4:04 AM
U
U Offline
I did a short cut and did not repair my hinges and now I am paying for it. I found this out when I installed the rubber door seal on the passenger side. The body shop adjusted the door without the seals. The doors opened and closed fine without the seals. Once seals in, the door would not close. I now have the seals and doors mounted but I have no idea how to make them shut. They are way off. Help! Thank you!
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
nothing to do with repaired or not - loosen the bolts on the pillar side of the hinge for adjustment in/out - the bolts on the door side of the hinge for front/back - both sides will also affect up/down
usually new seals cause the door to be quite tight, sometimes enough you have to slam it pretty good to catch the latch, to some extent that improves with use as the seals 'crush' a bit .... of course there's also the fact that some repro seals are too thick for proper functioning, been some posts about that problem not long ago
