7 members (32Fordpuchoptop, Nhluvstruck, 1955 1 Series, Steve 210, DHedrick, Bill Hanlon, 1 invisible),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | im having issues ID'ing the motor in the truck i recently bought, Its a 66 chevy c-30 with a v8. im getting alot of help from other forums here, but my question is; im tearing down the motor, does the distributor shaft go through the intake manifold? the ones i was looking at online seem like they have a hole for the distributor at the rear. this is the first pre 73 truck ive ever had, and im still kind of lost on some of it. i dont know the motor size yet, but is definitely a small block.
66' Chevy C-30 Rat
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Yes, the distributor goes through the intake so it will need to be removed first. Also, drain the coolant before loosening the manifold or you'll flood the crankcase with antifreeze. Drain both sides of the block before removing the cylinder heads. Jerry
| | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | hey great tips, thanks! any tips on removing the distributor?
66' Chevy C-30 Rat
| | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | The distributor is held down by a fork-shaped clamp secured by one bolt. Remove the clamp, disconnect the wiring, and lift straight up. Jerry
| | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | and when i put it back in (assuming i dont rotate the motor) is there anything tricky, or can i just make a mark on the housing and on the manifold and line them up?
66' Chevy C-30 Rat
| | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | The distributor drives the oil pump so when you remove the distributor the oil pump drive shaft turns. You can align the oil pump shaft with a screwdriver and then drop in the distributor. Or you can set the distributor in place on the correct gear and then crank the engine over and the distributor will drop in place. Fred
| | | | | Joined: Apr 2010 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 126 | cool thanks a lot! got the distributor out yesterday after work.
66' Chevy C-30 Rat
