1 members (LAROKE), 127 guests, and 2 robots.
Topics128,196
Posts1,057,393
Members48,471
I have an opportunity to jump in on an order and save some big bucks on a new set of wheels and tires for my 1946 1/2 ton.
The problem is that my truck is apart being painted so I cannot get the measurements I have been asked for.
I am looking the measurement from the drum to the inside of the front and rear fenders. My truck is all original.
I believe all other measurements can be taken from my truck once I have this reference point to work from.
The pictures of original trucks seem to show there is some room to play with. I hope that is the case.
Any help would be appreciated. Thanks, Aaron
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Look through HERE. You should be able to find the info you need...joe
Thanks Joe. I was looking this over last night (page 57). The numbers are not too clear but I am sure I've got it right.
I will compare the numbers that I can against my truck, just to be sure.
The best I can expect is to be fairly close. It will have to do as today is my last day to get it sorted out.
Thank you.
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Good Luck...joe
