0 members (), 106 guests, and 2 robots.
Topics128,115
Posts1,056,292
Members48,439
im having issues ID'ing the motor in the truck i recently bought, Its a 66 chevy c-30 with a v8. im getting alot of help from other forums here, but my question is; im tearing down the motor, does the distributor shaft go through the intake manifold? the ones i was looking at online seem like they have a hole for the distributor at the rear. this is the first pre 73 truck ive ever had, and im still kind of lost on some of it. i dont know the motor size yet, but is definitely a small block.
66' Chevy C-30 Rat
Yes, the distributor goes through the intake so it will need to be removed first. Also, drain the coolant before loosening the manifold or you'll flood the crankcase with antifreeze. Drain both sides of the block before removing the cylinder heads.
hey great tips, thanks! any tips on removing the distributor?
66' Chevy C-30 Rat
The distributor is held down by a fork-shaped clamp secured by one bolt. Remove the clamp, disconnect the wiring, and lift straight up.
and when i put it back in (assuming i dont rotate the motor) is there anything tricky, or can i just make a mark on the housing and on the manifold and line them up?
66' Chevy C-30 Rat
The distributor drives the oil pump so when you remove the distributor the oil pump drive shaft turns. You can align the oil pump shaft with a screwdriver and then drop in the distributor. Or you can set the distributor in place on the correct gear and then crank the engine over and the distributor will drop in place.
Fred
cool thanks a lot! got the distributor out yesterday after work.
66' Chevy C-30 Rat
