6 members (TUTS 59, 2-Ton, Forty9, Stovebolt48, cmayna, Goach2), 56 guests, and 5 robots.
Topics128,203
Posts1,057,412
Members48,471
' Offline
I'm going to register my 54 3100 in Washington State and they want the Gross Weight. I'm seeing 4,200 # on the internet. This sounds too heavy. Do you have the actual Gross Weight of the truck? Regardless of the new V8, etc., I think the original weight will do.
When they ask for "gross weight" do they want fully loaded capacity, or unloaded "curb weight" which is much lower?
Riding in the Passing Lane
If it'slike the states around here, they want the max. it will be carrying &/or pulling. Like if you are licensed for 8,000 lb's you can't go over that or you can face serious fines.
1972 Chevy c10 Cheyenne Super
' Offline
Well, I'll tell them 4,200 pounds. But, I suspect after swapping the 6 cylinder for a small block V8 and getting rid of those bulky rear and front springs it's a lot lighter.
