| | | Forums66 Topics128,029 Posts1,055,416 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | My question is how do you set the timing using the flywheel. i hear you need to line up a type of ball with a small window mark next to the starter. how is this done? i need info on this, thanks | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | It isn't really any different that timing off the balancer. The window is just above the starter, there's a pointer in the window. When the ball embedded in the flywheel lines up with the pointer, that's TDC #1 cylinder.
Bill Burmeister | | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | So at Top Dead Center thats where there needs to be the spark for cylinder 1? I made a mistake because i removed the dist. without making where the rotor pointed, now everything is screwed up. | | | | | Joined: Feb 2004 Posts: 29,748 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,748 | The ball aligns with the pointer twice, once when the #1 cylinder is in firing position, and again when #6 is ready to fire. You need to be sure and pick the right cylinder to align the distributor with. Put your thumb over the #1 spark plug hole, and bump the starter over until you feel a puff of compression. Then turn the engine over slowly until you see the pointer & ball align, and drop the disttibutor in with the rotor pointing toward the #1 plug wire. With the ball & pointer aligned, turn the distributor housing counterclockwise until the points just barely open and lock it down in that position. The timing should be close enough to start the engine. Warm it up and do a final timing check. BTW, the ball is not TDC, it's about 5 degrees before TDC, where the timing is supposed to be set. Jerry
| | | | | Joined: Nov 2006 Posts: 37 New Guy | | New Guy Joined: Nov 2006 Posts: 37 | CenCal53
You can also use a dab of white out on the ball that is embedded on the flywheel. Makes it a little easier for the eye to pick it up.
Just a suggestion.
Hope this helps.
Kent S Butler '56 Chevy 3100 Houston, TX
| | | | | Joined: May 2008 Posts: 84 Shop Shark | | Shop Shark Joined: May 2008 Posts: 84 | I appreciate all the help, i have my engine running now | | | | | Joined: Feb 2004 Posts: 29,748 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,748 | "I love it when a plan comes together!"
BTW- - - -I used to race Northern California Sportsman dirt track cars on a 1/4 mile track in Watsonville, back in the late 1970's! Jerry
