2 members (Hotrod Lincoln, Shade Baby), 66 guests, and 1 robot.
Topics128,157
Posts1,056,875
Members48,458
hi a friend of mine hase a 79 blazer k5 frame complete with axle diff motor stering . i wonder dos a housing and bed fits from a 59 apache
thanks
gregor
A good friend of mine mounted a 59 Apache on a mid seventies Blazer 4wd chassis and it turned out quite well. He drove it for years and used it for a long while after that to pull his fishing boat since the 4wd worked well for pulling up slippery boat ramps. Of course it DOES NOT FIT without making up custom mounts, adapting the steering, and many other things that are part of a body/chassis swap. I do remember he had to shorten the bed. He probably has pictures of the finished truck but not of the build process.
Evan
The Blazer frame will be much shorter, so either shortening the bed ans coilover mentions or lengthening the Blazer frame will be required. Alternatevely, you chould just adapt the axles and engine/trans/transfer case, and steering to the original '59 chassis, which will maintain the factory mounts and wheelbase.
Bill Burmeister
hi
would be great to see a photo . and mayby your friend can tell me a bit about chanching it
thanks
gregor
my e mail is
[email protected]
