9 members (Otto Skorzeny, WICruiser, Peggy M, FAST55, Bucker, wilbur53, GMCJammer51, Forty9, 1 invisible),
63
Mod | | | Forums66 Topics128,159 Posts1,056,900 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 27 New Guy | | New Guy Joined: Sep 2009 Posts: 27 | hi a friend of mine hase a 79 blazer k5 frame complete with axle diff motor stering . i wonder dos a housing and bed fits from a 59 apache thanks gregor | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | A good friend of mine mounted a 59 Apache on a mid seventies Blazer 4wd chassis and it turned out quite well. He drove it for years and used it for a long while after that to pull his fishing boat since the 4wd worked well for pulling up slippery boat ramps. Of course it DOES NOT FIT without making up custom mounts, adapting the steering, and many other things that are part of a body/chassis swap. I do remember he had to shorten the bed. He probably has pictures of the finished truck but not of the build process.
Evan
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The Blazer frame will be much shorter, so either shortening the bed ans coilover mentions or lengthening the Blazer frame will be required. Alternatevely, you chould just adapt the axles and engine/trans/transfer case, and steering to the original '59 chassis, which will maintain the factory mounts and wheelbase.
Bill Burmeister | | | | | Joined: Sep 2009 Posts: 27 New Guy | | New Guy Joined: Sep 2009 Posts: 27 | hi would be great to see a photo . and mayby your friend can tell me a bit about chanching it thanks gregor my e mail is [email protected] | | |
