8 members (Peggy M, DaveV, 2-Ton, TUTS 59, JW51, walter74, moparguy, 1 invisible),
159
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 14 New Guy | | New Guy Joined: May 2010 Posts: 14 | Hi all! I have a 48 2ton with a mid to late 50's 235 engine, from what i was told. What is the setting and procedure for checking the timing? Thanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The procedure should be similar to the one described in the 1955-2nd series Truck Shop Manual. Welcome to the discussion boards. If you are going to keep you truck for a while, you might want to obtain an Owner's Manual and Shop Manual for the year of your truck and for the year of your engine. Check the Links section for names of vendors that sell these manuals (or, check out eBay). Post the various casting codes and serial number and people will try to help you identify the year of your engine. | | | | | Joined: May 2010 Posts: 14 New Guy | | New Guy Joined: May 2010 Posts: 14 | | | |
