4 members (Wayne67vert, Gray_Ghost, BC59, 1 invisible), 155 guests, and 2 robots.
Topics128,164
Posts1,056,965
Members48,458
I need to replace the rear axle housing on my 55 first series P/U, a 3100. The info I've been able to find tells me that I can use any housing from any 52 - 55 car or 1/2 ton P/U.having to change the carrier because of the open driveline. Can anyone shed some light on this?
Any 1951-62 1/2 ton housing will have Bendix brakes, same axles, and pumpkin set-up and will fit.
You will need to do work on the spring mounts with any other housing.
My Blog
Any of the torque tube rear ends will have a different spring mount than the open driveshaft housing. Aslo, I think that 57 and later had pads designed for wider leaf springs.
