0 members (),
118
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | I am reaching the point that I will have to buy tires. I want as much diameter as possible, but with minimal width. I want to counteract the 4:11 gearing, but I don't want to get away from my stock 15x5 1/2 rims.
Has anyone messed with this enough to know what current common sizes are available...in the tall department??
Gary | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Unfortunatly, if you want narrow and tall, there just isn't anything available in a modern tire. 27-28" is about all you're going to get and stay under a 7" tire width. Even then, the 5.5 rims may be too narrow. Also, with a modern radial, you'll have to go with a single peice wheel, tubeless tires do not work very well with multi peice wheels. You might want to check with Coker or Denman, they may have a bias ply that will fit what you're looking for.
Bill Burmeister | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Coker is too spendy. My rims aren't multi-piece. They are the "artilery" type, and 15 inch. 28 seems to be about the tallest that I have been able to find, so I guess that's going to be my limit. I haven't compared with the originals, though. I will do that. I think they were either 6.70s or 7.60s.
Gary | | |
