1 members (Gray_Ghost),
65
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Hi, i have a 57 GMC pickup that i got from my uncle that i am working on. It has a Ford 390 engine, a 4 speed toploader transmission, and 4.10 gears in the rear axle. I know that this is a wierd setup for a GM and I plan on keeping all of this the same. My question is how fast will i be able to go with this combonation? it's not going to be a racer when im done, i just dont want to poking along in the slow lane when im driving. i want to be able to drive highway speeds easily. Thanks | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | How tall are your rear tires and how high do you want to spin that 390? There are many online calculators for rpms. I have a formula to do the math the old fashioned way, but it's out in the garage.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Here's one good calculator http://www.onlineconversion.com/bigger_tires.htmJust for guessing and illustration purposes: 3000 RPM 30" tire 4.10 axle ratio 1.0 transmission ratio = 65 MPH | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Early top loaders were direct 4th. 77,78 offered a .81 OD. The early 80 top loaders with the aluminum case offered .81 as well as a .70 OD. So a lot of it depends on which top loader you have. Even if you have the direct 4th, the FE motor will go faster than you you can keep your 57 on the road and certainly faster than you can stop if it you have to make a panic stop. But keep in mind that the faster you go, the more gas it will guzzle. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | You should easily be able to run 80 or 90 unless you put real short tires on it. The motor will be spinning fast and drinking lots of fuel...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Ok Thanks, I just wanted a ballpark figure so i know what i will have incase i wanted to change anything. Thanks a lot | | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | All about those gears, I had a '65 3/4ton that would run 80 all day long even with a 5.some-odd rear end on 16.5 wheels with tall rubber on em. It had a 327, started with a 4-speed out of a mid 70's Vette and ended up with TH400. Stopping power was good coz I always kept my brakes in good shape. That & I'm a firm believer in the term "moving is optional, stopping is mandatory".  1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
| | | | | Joined: Mar 2010 Posts: 118 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 118 | Would it be possible to have a shop put in that .81 OD gear for fourth? Could you swap them out? Or would it just be easier or better to change the rear axle ratio? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | you couldn't 'put the gear' in your current trans, you'd hafta find a trans that's already got it .... and it depends on just what the trans is you have now, hooked to a Ford, it may be a Ford trans .... easier or better is a personal choice, based on yer bank account and parts availability
Bill | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | The Ford toploader was a product of Ford engineering. It was produced in well over 100 different models. I have had limited experience with them because I mess with Y-blocks as well as GMCs. However, a transmission shop that specializes in the 60's and 70's muscle car boxes would be much more qualified.
