| | | Forums66 Topics128,015 Posts1,055,335 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2008 Posts: 95 | I notice in the catalogs that there are two types of head light terminal blocks.3 and 4 position.What is the extra position for on the newer trucks? I'am working on a 51" and using the 54' assembly manual.It shows the 4 position, but mine had two 3 positions when I took it apart. Thanks | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | HERE'S a wiring diag. for the '54, looks like they used one terminal for the horn. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | When I wired my 52 I installed turn sig. so I used 4 poss.terminal blocks.
Pete
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If you are NOT trying to be period correct, Home Depot sells plastic style terminal blocks that will work and are much cheaper then the those in the truck catalogs.
Drew
| | | | | Joined: Dec 2006 Posts: 720 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 720 | You can also get terminal blocks that look similar to stock from boat shops like West Marine for less than some "specialty parts", & best part about those is many are made of corrosion resistant materials. 1956 GMC 370 dump " 'Tater "1970 VW Volksrod "the Black Bomber" 2007 Chevy Avalanche 2020 Jeep Cherokee Trailhawk, 2005 Harley Davidson FLHTCUI I dig all cars, old and new, whether they were hammered out of American iron, German steel, or Japanese tin cans. Being unable to appreciate them all is missing out on a world of great things. But thats just MY opinion! :P
