4 members (Rich'sToys, Hotrod Lincoln, TooMany2count, 1 invisible), 130 guests, and 6 robots.
Topics128,021
Posts1,055,354
Members48,420
#640 09/09/2002 3:05 PM
Got a 50 3600 that came with a 235 in it. When I run the numbers it turn out to be 1956 235. The head is stamped 848. In the swap meet there is a reference to a high compression head 848. What do I have? Is 848 a different head than normal. I currently have motor/trans out to do work on de-rusting frame and repairing fire wall and floor. I had no plans to work on the motor since it runs good and doesn't smoke. While I have mtr. out I was going to pull the pan and clean out any gunk in there. Any thing else I need to do? I back flushed the cooling system before I pulled out the mtr. and will take radiater to shop to be rodded out
#641 09/09/2002 5:50 PM
The '848' is the best factory head for the 235, it offers the highest compression and flow. It is also the most common. Every 235 I've ever seen comes with one. The 261's used a differant head with lower compression so an 848 is desirable swap onto a 261 after drilling the steam pocket holes out.
Paint & Body Shop moderator
