3 members (Gray_Ghost, greenie-reddy, carbking), 55 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#64032 08/08/2006 2:55 PM
Junior Member
Junior Member
I have a 53 ,3100 GMC that I drive daily. I would like to 4 wheel drive it. Open the drive line. But do it with a 235. I still want to keep it stock looking on the outside. How would a person do something like that?
#64033 08/09/2006 6:15 AM
There is one running around here that I see from time to time. I thought I had some pictures of it, but I can't find them. Its a long-wheel-base GMC 1/2-ton.
It appears to have 70's 1/2-ton four-wheel-drive axles using the stock springs. It has a V-8 and automatic, but that part isn't really your challenge.
Find axles that are not too wide, and realize that you are going to have to lift the truck up to fit the front axle underneath.
Find a 4-speed or 5-speed with transfer case, married or divorced, that are compatible, and from a Chevy or GMC, and then mount the 4-speed to your existing bellhousing, and add a crossmember to support the transfer case.
Then have drive shafts built.
Over simplified maybe, but unless you are going to go with a different frame with independent front suspension, you are going to need to raise the truck up. Going IFS four-wheel probably means a frame swap. Keeping the 235 either means using an adapter to put an automatic behind the 235, or the GM manuals that will fit your existing bellhousing.
I wish you were closer to me, this is a project I'd enjoy watching.
If I were doing this I'd try it different. I'd swap to a four-wheel-drive S-10 frame because it can allow keeping a stock ride height. Mounting a 235 in that frame might be a challenge...
#64034 08/09/2006 2:26 PM
Junior Member
Junior Member
Thanks my man, I'm still kicking this thing around but one my buddys told me about the s10 thing. I wonder what model s10 would work? Heck I guess I could use the engine out of that thing too.
#64035 08/10/2006 2:22 AM
Keep this in mind as well Mike- if you keep the six, you will need an offset diff on the front axle to clear the oil pan. It isn't such a big deal with a v-8 because a v-8 has a shorter height than an I-6
-Lurch
-John
'61 Apache 10
'93 Suburban
'04 Envoy (Straight Six!!!)
If it ain't loud, I ain't interested
#64036 08/10/2006 5:33 AM
Toyota four bys used the 235, so maybe you could use the transfer case and axles from one of them.
#64037 08/10/2006 6:56 PM
Junior Member
Junior Member
I know ya'll are going to hate my guts but I like that S10 idea. But what about this, using a Toyota 4 runner are something like that?
