| | | Forums66 Topics128,029 Posts1,055,416 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 74 New Guy | | New Guy Joined: Apr 2010 Posts: 74 | Hello,
Ran into what I suspect is going to be an issue with my 216. I noticed that the fuel bowl tends to drain out back into the tank after the vehicle is shut off. I am not sure this is supposed to happen? I know most newer cars keep the fuel pressure spiked past the fuel pump, (had there been a bowl it would be full). Anyway, yesterday the car ran for about a full minute and then just shut down. Appears as though the Carb used all the fuel remaning and the pump did not fill the bowl up adequately enough to keep it running. After teasing it finally I got it running, revved it up, and the bowl filled, but not entirely. Is this a weak fuel pump or normal for these cars? How do I test the fuel system?
Dan
1946 Chevy Stylemaster Sedan - 216 6 Cylinder 1971 Chevelle SS 1995 Monte Carlo Z34 2005 Corvette Z51
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | could be a weak pump and you can do a pressure test, could be the float setting, but the bowl isn't supposed to be "full" [like a pressurized system], there's a proper level setting .... it doesn't "drain back to the tank", pretty normal for most of these old carbs to leak and evaporate the fuel out of the vented carb float chamber if they sit for even a couple days, it could be you're just not running the truck enough
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | By fuel bowl are you refering to a glass filter bowl or the fuel bowl in the carb? Sounds like you need to to test your fuel pump & blow out the lines. Look for a filter in the line from the tank to the pump. Sometimes a PO has installed a filter under the cab. I know I do. If the pump hasn't been replaced for a long time it's a good idea to put a new one on. Most of the gas we get now has ethanol in it & can damage old fuel components.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
