1 members (Gray_Ghost),
83
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Dumb question # 39…..Where does the windlace go? On the door or on the cab my guess is the cab, but might as well be sure. Also has anyone managed to get it on all in one continuous piece??... I’ve hade the stuff for a while now, but never tried to install it. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | frame of the cab bro.openings
dan-pa
| | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | Good question Kip, I know it mounts to the cab, but what about around the dash board? I took a look and this is what I found. The cab windlace starts at the bottom of the kick-board and continues around the arch of the door below the seat, all as one piece. Looks like the dash would need to be off for a proper fit?
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Guess I will not get a "proper fit" as the dash is not coming back off any time in the near future. Thanks for the info. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I installed in one continuous piece from floor at kick panel up and around, back down to floor at rear of seat. Metal trim piece screws over flange of windlace. Had enuf room to get by ends of dashboard. | | |
