7 members (Youngin' Tut 59, latroca52, Donf, Lightholder's Dad, Jon G, Hanks custodian, 55shaker),
73
Mod | | | Forums66 Topics128,185 Posts1,057,284 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | the bearing retainer from my sm420 requires a spanner wrench to rmove it. i have a spanner that fits but this reverse threaded reatainer is really on there. i was thinking of welding a cheater onto the spanner but i think i would just break the pins off the spanner.
does anyone have a suggestion or tip on how to get this retainer off. the bearing behind it is shot. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I generally use a narrow chizel & catch the edge of a flat & tap it off. They usually arn't tight though. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i tried using a punch by placing it in one of the holes the spanner pins fit into. it did not budge.
i called a local transmission shop. they are going to give it a try tomorrow.
plus i ordered my rebuild kit from novac. it should be here by friday. | | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | i ended up using a friends air wrench with a punch. i buggered up the holes a bit. in 2065 when the transmission gets rebuild again, i hope my great grandaughter doesnt curse my ham-fisted technique. | | |
