| | | Forums66 Topics128,167 Posts1,057,015 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#63934 08/06/2006 3:45 AM | Joined: Jun 2006 Posts: 96 Member | | Member Joined: Jun 2006 Posts: 96 | My 1949 3600 shudders or chatters real bad when letting out the clutch. It's much worse when cold and/or on a hill, especially in reverse. Once the truck has been run for a few miles the forward gears are OK. I went in to r&r the clutch but found that the intermediate driveshaft bracket was completely missing the carrier bearing rubber cushion. There was an inch of play in the driveshaft carrier bearing support bracket so I figured that I had found the problem. Since the problem is much worse in reverse I'm starting to wonder if the brakes are grabbing. Once I tried reverse and forgot to let out the e-brake and found that the problem felt exactly the same. Any thoughts? I'm going to go through the brakes next week. I only bought the truck a couple months ago and the brake lines, cables, brackets, and inside the hubs are all new. I have not seen inside the hubs yet; just going on what the seller told me. All of the other brake parts are noticeably new. | | |
#63935 08/06/2006 4:27 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | leon2982,
Your problem sounds like classic clutch chatter to me. The bum center bearing support might have added to it...a little, but a new clutch, pressure plate and flywheel surface will probably fix the problem nicely.
Reverse would tend to exacerbate the chatter because it is geared so low. If you have oil getting into the clutch area, that might complicate matters.
Stuart | | |
#63936 08/06/2006 9:04 AM | Joined: Jul 2005 Posts: 71 Member | | Member Joined: Jul 2005 Posts: 71 | I'd agree with atomarc. The only thing I would also look at would be the mount rubbers. My brother has a CCKW which tore one mount. Letting the clutch out in the forward gears,with the torn rubber,was not a problem but in reverse the motor would nearly climb out of the engine bay.Maybe your mounts are getting soft too. | | |
