| | | Forums66 Topics128,055 Posts1,055,783 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I've got a tilt column out of a late 70's or early 80's Chevy van. I wanted to see if someone could help me sort out what each wire goes to. 8 wires. Black Light blue Dark blue Brown Purple Yellow Green White | | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | White..Stop Light Switch Green..R.R. Lamp Yellow..L.R. Lamp Purple..Turn Signal Flasher Brown..Flasher Dark Blue..L.F. Lamp Light Blue..R.F. Lamp Black..Horn Orange..Ignition Switch Dark Green..Ground Tan..Ground Red..Battery 12 V Brown..Acc Fuse Box Pink..Ignition Coil Red..Battery Fuse Box Purple/Dbl White Stripe..Start On Solenoid | | |
