| | | Forums66 Topics128,094 Posts1,056,056 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 13 New Guy | | New Guy Joined: Oct 2009 Posts: 13 | hi, i just looked over your tech tip about using a Camero front clip on an AD truck....i'm wondering, could i use a 76 pontiac firebird front clip on my 53 Chevrolet 3/4ton? or are there to many differences?
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The Camaro and Firebird clips are the same as far as I can determine. The last one we used was believe it or not a 76 Firebird onto a 48 half ton five window. The biggest problem was getting front wheels with a back spacing that put the tire inside the fender and also cleared all the suspension components. The final ride height will be determined by how you splice the clip to the AD frame. I have pictures of each way---one puts the nose in the weeds and the other is at nearly normal height. We have gotten a lot of abandoned projects due to botched clip installs so the best advice I can give you is to measure all the dimensions AND ANGLES of the donor car suspension BEFORE the clip is removed so they can be duplicated on your truck. Also measure every possible point of your truck front end before it is removed and write those measurements on the firewall with a marker so they can't be lost. Good luck.
Evan
| | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | A crossmember kit is easier than a clip.
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | A clip is the "cheapest" way to go, if you do it yourself. If you hire the job out, I doubt if you'll save money vs crossmember kit. The problem with clips, plan on rebuilding the suspension components. If you've never done one get all the information you can, before attempting this. I speak from experience, I built mine to "low". It looks good, but I could have saved myself some headaches if I'd only known. Done right you can improve handling, steering, brakes, done wrong and you might as well scrap the project. Next time I'm going with the IFS crossmember. | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | Time to buy the Danforth front crossmember! | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I realize that buying an after market independent front suspension is quite costly.But everything is right there to start your frontend changeout.True you can go to a bone yard and buy a front clip fairly cheap,but then figure in the cost of rebuilding it,and you are right back up there with an aftermarket kit,money wise.I was pretty lucky when I did my 55,I had a freind who was a dealer for the TCI setup, and I bought the unit at his cost. The installation was a snap,with only one phone call to TCI about the power steering install.And they were very helpful,explaining what pump to use,etc.So to me its gonna cost a lot of money,no matter which way you go. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | The cheapest way to go is still a dropped axle from sids with new springs and a disk brake kit.
my kit with tubular uppers and salvage yard parts will be about $1k to install (not including welding supplies) if you do it yourself. If you hire out the welding, add $300.
