| | | Forums66 Topics128,023 Posts1,055,370 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 26 New Guy | | New Guy Joined: Mar 2010 Posts: 26 | looks like all i need to do is change the bell housing and front timing cover or bracket the front mount goes on. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You need to tell us what truck and what year 235 to get good answers. There are different bell housings and different 235s to take into account. I can only guess you are putting a '55-59 engine into a '53 or older truck. If so you will need to keep the old bell housing. If the later engine has a lip on the timing cover you can drill holes in it. If not you'll have to change it. You'll also have a water pump issue. There are several ways to resolve that.
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Actually 1954 had the different bell housing,it was beveled where the mounts go.I think 1954-1959 are the same. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | That's what I said. A pre-'53 will need to keep the 216 bellhousing.
To add too it, to keep a 6V starter you need to use the earlier flywheel. If you use the later flywheel you'll need to change to a 12V starter. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | you said 55-59,nothing about the 1954 engines belhousing being different. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If he has a '54 235 engine then it's a different story. I said I was guessing he was using a '55-59. I base my guess on his statement that he might need to change the timing cover. If it were a '54 235 it would have mount holes in the cover. I have no idea what he's using. You don't either so why do you want to argue about it?
| | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I'm not arguing,just letting him know that the 1954 bellhousing is different. 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Mar 2010 Posts: 26 New Guy | | New Guy Joined: Mar 2010 Posts: 26 | the 235 is from a 55 and i am putting it in my 51. the 55 bell housing has a slant where the mounts go and the bottom of the timing housing has no holes in it. i thought i would just swap them. thank you for all your help. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | To swap those plates you must drop the oil pan and pull the cam. It's much easier to drill the holes. Someone posted a few days ago that there is a Stovebolt tech tip on locating them. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2010 Posts: 26 New Guy | | New Guy Joined: Mar 2010 Posts: 26 | cletis,thank you. after reading some of the helpful words i thought that drilling what i had should work great | | |
