| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 11 New Guy | | New Guy Joined: Jan 2010 Posts: 11 | I want to replace the 235 six in my 60 C10 with an early 60's 283. I plan to keep the 4-speed that is in the truck now. The engine has a cast iron bell housing and is bolted to a heavy duty 4-speed from a 53 school bus. My question is exactly what motor and frame mounts are necessary for this swap and what else do I need to change? Thanks. | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | 60-61-62 came with a hydraulic clutch actuator mounted on the bellhousing. You will need a V-8 bellhousing from one of those three years. You will also need a V-8 flywheel. The clutch can possibly be used if it is the same size as the V-8 flywheel you obtain (either 10" or 11"). The rear mounts on the bellhousing/crossmember are the same but nothing from the 235 will interchange with the V-8. Try to find the stock front or side mounts from a V-8 truck otherwise there are some aftermarket mount kits. Fred
| | | | | Joined: Jan 2010 Posts: 11 New Guy | | New Guy Joined: Jan 2010 Posts: 11 | The 283 has a flywheel and clutch assy. attached to it now. I am uncertian as to the year of the bellhousing. I will try for a casting number I.D. Thanks | | |
