0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 11 New Guy | | New Guy Joined: Dec 2009 Posts: 11 | i have a 65 with a 230 six all stock. underdog as it is known as needs a tune up real bad, i want to put a ignitor in to eliminate the points in it. my question is where should the timing be set at. any info would be greatly helpful. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | sorry for my "dumbness" but i don't know what a ignitor is. but when i put hei dist in any of mine seems like i have to advance it a little. it seems to run better than the stock 4 deg btdc. i have heard others say they have not had to do so and their hei runs good at stock setting. i guess you can set it where it runs best. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Pertrinics Ignitor points eliminator. Basically achaive the same thing as going to HEI, eliminates the points for electronic spark triggering. I do agree with advancing the timing. I had a similar issue with the Mallory Magnetic Breakerless i have in my 235. Ended up going with 15 degrees BTDC, however, I am not running a vacuum advance.
Bill Burmeister | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | thank you for the explination longbox55, tons of stuff i don't know. one of the many good things about this board. | | |
