9 members (Cosmo, Samantha, Otto Skorzeny, Brian Moore, Jims46, Ponchogl, moparguy, KEVINSKI, 55shaker), 83 guests, and 2 robots.
Topics128,030
Posts1,055,424
Members48,422
#638068 04/16/2010 1:29 AM
i have a 65 with a 230 six all stock. underdog as it is known as needs a tune up real bad, i want to put a ignitor in to eliminate the points in it. my question is where should the timing be set at. any info would be greatly helpful.
kingko #638106 04/16/2010 4:03 AM
sorry for my "dumbness" but i don't know what a ignitor is. but when i put hei dist in any of mine seems like i have to advance it a little. it seems to run better than the stock 4 deg btdc. i have heard others say they have not had to do so and their hei runs good at stock setting. i guess you can set it where it runs best.
hoggyrubber #638110 04/16/2010 4:11 AM
Originally Posted by hoggyrubber
ignitor
Pertrinics Ignitor points eliminator. Basically achaive the same thing as going to HEI, eliminates the points for electronic spark triggering.
I do agree with advancing the timing. I had a similar issue with the Mallory Magnetic Breakerless i have in my 235. Ended up going with 15 degrees BTDC, however, I am not running a vacuum advance.
Bill Burmeister
LONGBOX55 #638147 04/16/2010 5:47 AM
thank you for the explination longbox55, tons of stuff i don't know. one of the many good things about this board.
