| | | Forums66 Topics128,113 Posts1,056,618 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 70 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 70 | My Fenders are good except where the running boards bolt on would you replace the whole fender or just do replacement's on the bottom? or do they make replacement parts for the bottom fenders ? thanks all
frankenstein Fabrications
| | | | | Joined: May 2005 Posts: 334 'Bolter | | 'Bolter Joined: May 2005 Posts: 334 | Hi jpmanyhearts, Not trying to run you off, but you might get good responses if you posted this question to a Ford forum instead of a Chevy/GMC forum (stovebolts = Chevy/GMC). Samantha | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | It's still a truck question and we can give a generic answer. It's about a process or what would you do type of question.
Don't know about replacement panels, but sometimes it's easier to find a good fender and replace the old one. You can always sell the damage one and recoup some of your money. But if you have a truck that you are trying to keep from repainting, then the repair might be the right answer. | | |
