1 members (CuzzFuzz), 228 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
Ok..I know our hoods are tough to realign, so on my '53 3100, Im thinking I can pull the 216 doing this:
Remove radiator and frame, grill, front bumper and splash apron, and squeeze the motor between the front 2 fenders. (might have to take a couple things off the motor, but thats no big deal)
Anyone done this??
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
OLTrucks
Unregistered
OLTrucks
Unregistered
Do it that way all the time. Works great!
Mike
How about unbolting the tranny also and pulling it the same way (pull motor and tranny together)? Does it fit??
-Patrick
1953 Chevrolet 3100
OLTrucks
Unregistered
OLTrucks
Unregistered
I have always unbolted the trans and just pulled the engine and bell housing out together and set them back in that way. Kinda alot od weight out there with the trans hanging way out back.
Mike
yea that does sound heavy.
Are tranny's hard to remove if I leave the motor intact? (in case I dont want to rebuild my tranny right now)
-Patrick
1953 Chevrolet 3100
My shop manual says: "raise the engine, clutch and transmission from the chassis as a unit." I did it that way but would remove the tranny next time.
Engine removal w/tranny attached.
I installed the new 261 w/o tranny attached. Hood fits better now using the "au contraire" approach than it did before the engine swap.
The shop manual also says to mount the engine on a stand with the tranny attached. What kind of engine stands did they use??
Thanks! Good pictures btw.
What kind of modifications did you do, going from your 216/235 to the 261?
-Patrick
1953 Chevrolet 3100
Y
Y Offline
I would suggest removing the entire front "sheet metal" as a unit, and leave the hood in place. That will save a lot of fitting and panel alignment problems. It's been mentioned before, that the 4spd will not clear the cross member?
I think Im going to unbolt the motor and remove it...tranny is in good shape. I can always go in from underneath and get it later.
Its a 3-spd.
I just dont want to have to remove the sheet metal (i dont have room to store it and I dont want to scar up my nice paint job)
-Patrick
1953 Chevrolet 3100
Green_98,
Back in the day, they used to cut the top piece of the radiator support frame on both sides. Removing that and piece of metal with the latch hole in it allowed more room in the front to pull the engine. That's been done twice with my '48. The second time, they didn't weld it back so I took advantage of the extra room.
Cuts in top radiator frame piece.
I once looked at the approx. 31 AD trucks that were in the local yard and many showed evidence of cutting that radiator frame piece.
The 261 slapped right in. They make a water pump adapter to better center the fan since the pumps of the 235 and '61 261 are of different types and are at different heights.
Very nice Wally; now that I think about it, I think mine has been cut too. I dont have a saw or welder at the house, so I'll just unbolt it!
Still undecided about the 261...depends on the condition of my 216 block I guess
-Patrick
1953 Chevrolet 3100
